I have recently changed the control valve, o rings, washers, main piston rings, pump rings in the hydraulic system.I did not change or repaired the valve chamber.
When I tested it, it runs perfectly well in draft mode as well as position control mode but it instantly drop when I shut off the engine.
Do you think the valve chamber is the problem or there is some problem in the control valve installation.
