Thomas(MD)
New User
I have a 2680HD with cab and MFWD. 8 speed with
mechanical shuttle shift. The plow is mounted to the tractor on
a subframe not on the FEL. I have a DA cylinder for the up and
down functions and the standard meyer SA cylinders for left
and right angle functions (both are new). The hoses are
hooked into the rear remotes of the tractor. My problem is that
the plow will not angle right. It angles left fine but will only
angle a little bit past center going right. If I mess with it long
enough I can get it to work and once it starts working it is fine.
After the tractor sits for any length of time the problem returns.
I have switched the hoses top to bottom and even switched
them from one remote to the other with the same result. I am
baffled and would appreciate any insight. Thanks in advance
Thomas.
Thomas.
