MF 202. I have a small leak coming from the bottom O ring of the power steering valve. I replaced the O ring couple years ago but it did not fix the leak. I read that somebody fix a similar power steering leak with a seal expander product called [b:9a9c682a3b]Seal Lube[/b:9a9c682a3b].
I just wonder about the wisdom of using this product or if anyone is familiar with this product. I'm not about to take the valve apart again. The leak is not that significant and I can live with it by adding a little fluid every so often. It just bugs me a little bit, that's all.
