I purchased a Tisco 883928M91 replacement switch. When I check it electrically, what I see as the "heat" position is also energized in the start position.
My understanding of diesels is that heat is not required after the engine is warm or has recently been running.
1) Is this the correct switch? Correct switch operation?
2) Will it "really" matter if the heat is on during a warm start?
I have an electrical print for the tractor, however it doesn't help with the internals or operation.
1963 MF 35 perkins diesel.
