Looking at a MF 1100. Guy says 3-point lift quit
working when he got the clutch replaced. Attempts
to get PTO engaged makes gear grinding sound with
clutch depressed. Any thoughts on lift or PTO not
working?
How about power steering and brakes, and Multi-power if equipped? If the flywheel and/or PTO input couplers at the rear of trans fail the charge pump drive will be lost causing steering to quit also.
Powers steering works fine. left brake works fine, should have decoupled brakes to see if right worked also, may be out of adjustment.
