Tractorfan1
Hi guys, I bought a 1965 MF 65 gas this fall. It has the Davis model 99 front loader. This winter I was using it for snow removal, then one day the loader quit working. Well the last couple days the temps went above freezing. Now the loader works a1. So I guess I have water in the system. Problem is, I don't see a drain plug. On this loader the fluid is in the loader frame itself. I am stumped. The weather is going below freezing tomorrow, so I would like to fit it today. If I can't get the water out is there anything I can safely add to keep it from freezing? Also I should note the three point hitch quit working the same time. Which is now working as well. Any help is greatly appreciated. Thanks.
