I have a Massey Harris 44 Special with the LPTO option. I also understand that the PTO clutch on such models do have a habit of slipping under load since they are considerably smaller than the traction clutch. I have been told that these clutches can be "locked up" such that the live power is bypassed and this problem avoided. I have the wheels off of the tractor for some light restoration and access to the clutch behind the flat circular plate is fairly easy. My question is what is the procedure to secure the clutch disc to the pressure plate? Can it be done by just removing this outer cover or does the entire clutch/plate assembly need to be removed?
Thanks, Ben
Thanks, Ben
