watertreatpete
Hello all,
I have a Massey 235 that needs brake work. One side works OK the other doesn't do much, someone borrowed my tractor and drove it with the brake lock on. Has any one worked on them? How hard is it to do? Also I have large wheel weights and the tires are loaded. Some one told me this tractor has the same rear end (square axle) as used in tractors up to 85hp. Also I am told it has wet brakes. It is the orchard model I think, much heavier duty than a normal 235.
Thanks
Pete
Thanks
Pete
