Rear Wheels - TO30
Phazer42
New User
I am in the process of re-working my hydraulics and also my wheels. I have two sets of rear wheels for this tractor and of course, they are both different rim assemblies. The one set, no issues I have seen many places that sell that rim style. The other set, the outer section of rim is shot and needs to be replaced. The issue is that the part that mounts to the hub is completely round and doesn't have a "pedal" look to it for the 6 attachment bolts. Along with that, the rim was fully supported around its circumfrance where the rims that I see are more of the "pedal" design and need just have the bolt at a given location and not this bracket that goes all the way around. So, I guess my question is, can I use these hub mounts on the "pedal" designed rim? I would guess that I can?
Pedal?? Do you mean loop rims?? Almost sounds like you have a set of Ford Hat type rims which where common on the Ford till 1953 or so
(quoted from post at 16:00:27 01/07/15) Pedal?? Do you mean loop rims?? Almost sounds like you have a set of Ford Hat type rims which where common on the Ford till 1953 or so
Here is what I am reffering to as the "pedal" style rim.
Here is a picture of a wheel similar to what I have.
I would just post pics of my rim but its about 20 min away from me and I haven't had time to run over there.
Just trying to understand if I can use the pedal style rim with the other hub section or if I need one of those wheels specifically.
(quoted from post at 14:37:42 01/08/15)
They will interchange. Although to use Ford hat style rims,you will have to use carriage bolts and not the Ferguson style bolts.
The "pedal" is actually what they call loop style.
Loop style.
(quoted from post at 10:07:01 01/08/15) The "pedal" is actually what they call loop style.
Loop style.
Thanks! Looks like I will see about using the two different "rim" styles then - wasn't sure if it was a different rim or just an "update"
(quoted from post at 19:39:44 01/09/15)
Loop style.
Here you go...this shows that the two will work together. Early TE-20 Fergusons used the solid wheel center like the Ford N series but they used the loop style rim.
