There is a round diaphragm looking object that
threads into the front of the pump, it is leaking
and I have put in o-rings before as a temporary
fix, what is supposed to be there to fix the
problem? - maybe a copper washer or something?
Does that part itself go bad? It was leaking a lot
yesterday and I stopped the tractor and took part
off and replaced it back on the pump now I can't
get tractor started. I bled the pump but nothing.
I am now wondering if that part is sucking in air.
Whenever I have replaced filters or this o-ring
before I never had problem getting tractor started
before. It is also around 0 degrees here in
Southern Michigan.
Southern Michigan.
