I got the challenger running. The problem that I
have is when it is not under a load is that it pops
and backfires, but when I pull it hard it clears up.
Any ideas? Thanks for any help.
(quoted from post at 10:46:07 01/01/15) I got the challenger running. The problem that I
Any
4 special , Check the timing first . Timing marks on crank pulley should be 7 1/4- 8" from left side of frame, second check the valve clearances . i set mine at 18 thou. Dennis
