2705 cab door
Brown Swiss
Hey all, is there bushings in the hinges for the door on a 2705 it has too much wear in them. I don't see any listed in agco parts books, unless I over looked it. Thanks, Tom
I didn't see any either, shows one upper hinge plate, and early or late lower hinge plate. May be salvage yard time if you can't find any or repair what you have.
Thanks for looking guys! Yep might have to refurbish it, or something like that. The bottom one seems the most worn.
They are all worn like that. It is usually the lower hinge pin. We have fixed all three of ours, a 2675, 2705, and a 3505. We just make up a new plate and pin fabrication for the lower hinge.
Hey thanks, so the pin wears more? I wonder if they have harder steel in the door and softer pin, so the pin takes the wear, I am going to take it off and weld up the pin!
