(quoted from post at 05:26:04 12/17/14) Thanks, it's in a farm tractor not a puller so pretty close to stock rpms. How much will adding compression by milling the head affect operating temperature?
(quoted from post at 18:20:50 12/17/14) Didn't the MF 88 have a version of the Continental 277 rated at 60ish HP? Maybe some parts from it would work???
Ben
(quoted from post at 13:18:04 12/19/14) I am thinking of upping the HP on my 44 EFI tractor. I am using the stock throttle plate and shaft int he throttle body, it is 39mm or 1.3". I can get rocker arms with higher ratio.
