I will try to keep this short. Massey 65 4 cyl continental gas, that sat for a couple months and wouldn't start. Ended up being a wiring issue with the starter switch and push button ignition. But before i had help figuring that out i started replacing ignition parts. Solenoid, 12v coil, new wires, cap and rotor, plugs and plug wires, points and condenser, all gaps checked. Also carb kit on my marvel schebler TSX-695 type C.
It starts and idles now, but upon 1/4 throttle promptly bogs and stalls. I have gone through the carb 3 times. I feel like it is not creating enough vacuum to draw fuel up through the mixture screw and through the Venturi. It also sounds not as loud as i think it should. I am going to try a compression test and also check the sediment bowl screen next. Good spark across all cylinders. When i adjust the power mixture screw past 1 turn there is no change when throttling up. It bogs to stall every time. I can adjust idle seemingly fine.
I hope you guys give me a little advice i am a novice wrencher.
Thanks,
JB
Thanks,
JB
