Need help and i'm a newbie to this Forums and this would be my first tractor also. We recently got this tractor guy said around 1953-58 and i found NO serial number plate etc etc. to identify the body and also can't tell what motor it has but it has a 4 cylinder gas engine with the big carburetor Marvel shebler on it and a long water pump pulley.. It has reverse and 1,2, & 3 gears on the trans, with L S H…On lower left middle/front of motor block i found this serial number : Z134A500 AK Any help will be greatly appreciated..I also see a tiny plate on the right side i believe trans with 2 small screws and shows a letter B 20 an 11 or H : If you need additional images i can add no problem. ThanksPete
This post was edited by AMERICANA on 09/27/2023 at 08:04 pm.
