Hi all, so I have my old 165 torn down currently and am panning to put a new brake disc and shoe on the ipto clutch. But while I have the tractor torn apart and the hydraulic pump out i would like to resolve some issues there as well. Some background: The lift arms have very little lifting compacity and sometimes dont want to go down either. Also when I cannot hold an implement at any place besides the whole way up or the whole way down. It will not rest in the middle at any point. It has been like this for a long time. I am nearly positive the pump ( pistons/ valves etc) are in good shape because of some work we had done not to long ago. All that said, I have been reading in my manual and it looks like a sticking control valve, bad relief valve, and poor adjustments, might be my problem. Any other things i should consider? More importantly, how does one go about replacing the control valve? The manual makes it sound quite intimidating. Is this something a mechanical minded farm boy can tackle with some time and a wrench?
Thanks for your advice!
