can a 135 gas be converted to diesel?
jth88
I have read that a 135 3 cylinder perkins is a
diesel converted to gas. Could it be changed
back to diesel by just changing the sleeve and
pistons and installing injectors and a pump.
The block, crankshaft, camshaft, and few other parts are the same, but you need different pistons (I think the connecting rods are different from gas to diesel). A different cylinder head, injector pump, and some other parts to convert it to diesel. It can be done, but it's probably cheaper just get a complete diesel unless you take your time, and look around for deals on the parts you need.
