Dieseltech….question
Posted the problem with my 180 no hyd the other day, you asked if the multi power worked. Checked and it seems to work fine,is that something that may narrow the problem? thanks
The auxiliary pump has two gear sections in one pump, larger gears for hydraulic side and smaller gears for the MP and/or independent PTO. If the MP works pump is being driven, but still could have a key sheared on the hydraulic side.
