Narrow front 1030 Tractor
D17puller
What was the largest tractor Massey Made to have a narrow/ dual front wheels. Any help would be great and were I may find one. Thank you much!!
Andy
The 1130 had a tricycle option. The 1150 did not.
The tricycle option is not in the 1135 parts book.
Getting a 1130 NF would be difficult, and every Massey collectors wants it, so it will not be cheap...
1100 series parts list shows two steering gearboxes, one will work for both narrow and wide fronts while one is for wide front only as it has no support bearing for a narrow front. If the box has a top bolt on plate it has the bearing, if the box is plain on top it's for wide front only.
Where would one try to find one to fit? Say to loose weight for non turbo tractor pulling? What could be made to work and what price may we be talking for a narrow front?
(quoted from post at 09:12:24 11/27/14)
If it is to loose weight for Pulling, I suggest that you please spare the few tricycle for 1100 series that are out there and that you put a JD 4020 trycicle front on your massey. That would be easy because the JD is designed to fit between 2 rails and you probably want to use some sort of ligthtweight frame, with an aluminium oil pan.
Connection between the 6.354 and the front pedestal is a very weak point. So I would not consider tractor pulling with that stock setup anyway...
actually I would really like to keep it factory appearing. I am going to be pulling in a farm class non turbo. Just looking for options. Thank you for all of the help guys!
