Massey Ferguson MF35 Utility (Gas)
Frank BC
I recently purchased this tractor and am in the process of fixing it up. I have worked on numerous Ford 8N, 9N and Jubilee models, but this is the first MF. I am pretty impressed with it, it is quite a step up from the little Fords. I am looking for an electrical wiring diagram, I purchased the service manual from this site, but it does not include any electrical information. Is there one in the IT Manual that would cover this model? I have looked on the internet, but can"t find the right one. Also, I am not sure how the safety start interlock button is supposed to work, there is a small wire clip shown on some of the drawings I have found, but I am not sure what it does. Also the planetary for the transmission low range is missing, is this something that can be reasonably replaced? I am sure I will have more questions later, but that will do for now, thanks.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=92333
http://vintagetractorengineer.com/2009/01/wiring-diagram-massey-ferguson-35/
click link in vintage tractor and a PDF will come up
The neutral safety switch uses a bullit connector. The spring like clips hold the bullit connectors in place ( in safety switch). There is also a rubber boot that goes on top safety switch.
http://www.ebay.com/itm/Neutral-Safety-Switch-Rubber-Boot-Massey-Ferguson-Tractors-180776M1-/321176733561
Thanks for the reply Tim. That is what I was looking for. The vintage tractor one didn't match what I had, but the one from YT was pretty much what I needed.
