Is a pull start OK....
Hello Gilbert,
The advice is correct that you cannot tow a MP tractor to start it. The reason is that in LOW MP you have an overrun connection in the transmission so nothing is connected. In HIGH you need oil pressure to activate the clutch pack. Towing does not create enough pressure for this.
The easiest way is to fit another battery or use jumper leads off another battery.
DavidP, South Wales
