Set a small bale down & now No lift!?!
165 diesel(only mine for about 2 months). When we first got it I did some disc work in the garden & its a heck of a lot heavier than the `lil bale I set. I`ve had a gasser TO35 for 10+ years & have had the top cover off...kind of know drain hyd. fluid to bottom of inspection plate to see if bubble`n anywhere. The brake side has more then my 35...OH, my 35 doesn`t have the 2 levers under the seat(selector valve) so this Also is new to me! Any sort of advice would be Much appreciated!!! I`m going to try to post 3 or 4 pix now
I have the same selector valve. If you move either
of them it draws the fluid from the 3 pt. hitch and
the 3 pt. hitch will not operate. Try moving the
selector valves.
Yep, just like the others said, looks like both valves are in "nuetral" position. I think the one on the left should be locked in the back position. Lets us know if it works!
Bumped the hydro selector lever more than a few times and usually think the worse until I figure out what happened.
I Wish it was that simple! I put both levers in middle(neutral) position. I`m also perty sure it Was the left 1 that ran the 3 pt., but I`m not sure if I pushed it forward or pulled back. The bad thing is, she ain`t wanting to start now. The Good thing, just before I moved that bale, I replaced the block heater AND got the antifreeze ready for this cold thats coming(4 balls float`n...lol)! It almost acts like its out of time & a `lil smoke came from the little hole on top of the starter, theres a copper(ground I guess) that goes into the starter.Some of the connections look "crudded" so after the race I`m gonna do a little more wrench`n! Thank you folks for the ideas & Please keep them come`n...lol!!!.......Gilbert
