1959 TO-35 part
Hi. Roughly in the middle of under my tractor there appears to be a rectangle plate missing, as there is some exposed internal pieces/gears. It would have 4 bolts to hold it on. Anyone know what part this might be? I can take a picture later. Sorry, I know very little about tractors and engines for that matter. I just bought it a few weeks ago and just noticed it to be missing now...
Thanks!
My 1957 TO35 has the same plate.
I assume it's an inspection plate, you take it off
to adjust the clutch.
I would replace it as soon as possible to keep dirt
and moisture out of the clutch pack.
It is just a flat steel plate probably about 3/16 inch thick. It shouldn't be too hard to find one. A piece of plywood would serve until you do.
