jimbob1
We have an 1100 that the hydraulic seat doesn't seem to work.
It inky goes up about an inch when I move the lever. All other
hydraulics work. What could be my problem.
Its leaking somwhere. I would say the cylinder . Is probably scored and when you go up an inch you hit the bad spot and it won't go any farther.
Found the problem. Believe it or not the linkage was froze up. A bit if heat and some patience and it works good!
