Hello,
I need to replace the starter solenoid on my Perkins AG3.152 3 cyl engine. Can the solenoid be replaced with the starter left attached to the engine? I see there are two phillips head screws.
The is a lead at the end that projects out of the starter. It is attached to one of the solenoid studs. Do I simply bend that lead/tab out of the way and pull the solenoid forward, away from the mount casting ? Thank you
Is there anything else I have to remove to replace the solenoid ?
