Brown Swiss
I was picking corn with the 1105 and the 300 JD and the second load the picker was slowing down, well the pto to it. The pto won't pull much now, I changed the filter but it didn't help, everything else works great yet! Is this the disc going bad in the clutch, or seal in the valve under the dash or charge pump go bad? Had a seal blow once under the charge pump but then had nothing for pressure anywhere so don't think that is it. What do you think? Thanks in advance!
P.S. Three is company I guess, PTO on the 1105 today, head gasket went bad in the 2745 last week, and the 2705 is still down from seal blown around the input shaft. Just my luck.
