MF 85 PTO Clutch
around-to-it
New User
need help removing the Front Bearing Carrier out of the rear axle center housing. the manual says to use "puller screws" and i'm not sure just what that means or how to do it. sure hope someone can advise me on this matter, thanks
There are four bolts that hold the plate, and should be two threaded holes in the plate to use bolts in as jack screws to pull it loose. At least there were on the 85 and S90 I have.
