I just bought this tractor, I knew of these problems before hand so I am ok with having to fix them. So if you have any advice or tips for any of these, please post. Thanks in advance.
1. The position control lever has no response, moving this lever does nothing. The lift will go up/down only by moving the draft control lever near the top of its travel (this is the only way to raise/lower the lift). I feel that it might have a linkage issue inside? The PO had the lift pump rebuilt recently, maybe something happened then?
2. The LH trumpet leaks oil, bolts are tight but leaking near the bottom where it mates to the housing. I suspect I will need to pull apart and replace gasket?
3. Diesel fuel leaking from Injector pump. This is a very small leak and appears its from 2 different hard metal line fittings. One at the bottom rear of pump that might just be a copper washer. The other leaking line is at the upper rear. I have not followed these lines to see where they go and I did verify that they are tight. I guess I will have to remove them and inspect?
