Hi everyone,
The other day the IPTO brake stopped working for me so the pto shaft just kept spinning even when I flipped the lever to "off" position it has enough drag in there to even spin a bush hog or tedder ( with no load) without the pto lever on.
So today I pulled the lift cover and took a look. The disc brake is broken as I expected.
Any ideas where I can order a new disc brake, or entire clutch pack. It seems as if they are not so readily available....
thanks in advance...
