3165 industrial IPTO
rust-o
Hi everyone,
The other day the IPTO brake stopped working for me so the pto shaft just kept spinning even when I flipped the lever to "off" position it has enough drag in there to even spin a bush hog or tedder ( with no load) without the pto lever on.
So today I pulled the lift cover and took a look. The disc brake is broken as I expected.
Any ideas where I can order a new disc brake, or entire clutch pack. It seems as if they are not so readily available....
thanks in advance...
Look under 'MF165' and 'MF30', the 3 labels USUALLY have the same running gear parts, not engines, but from the clutch back. Good luck.
Any idea if i can just replace the brake disc or will I have to replace the entire clutch pack?
