Massey 44 and Massey 55
trainut
New User
Could one of you Massey guys with a parts manual for a 44 and a 55 tell me whether the spider gears in the differential (the 3 little gears) are the same in both tractors. I need the gears for a 55 but have found a 44 differential for sale. Thanks.
Hello
Are you referring to the 3 differential pinion gears? If so...it looks like they are the same (12 tooth) if your 44 has a serial number prior to 44ds3323 or prior to 44dr1733
Wayne
Yes I need the 3 little gears. The differential and the bull gears out of a Massey 55 make up the gearing for the back end of a 1/2 scale case 65 steam engine. When I moved somehow those 3 little gears didn't move with me. I had to buy a whole rear end just to get those 3 little gears to finish my steam engine. Now I see a guy on ebay has the differential with the 3 little gears out of a 44. I would have the gearing for another 1/2 scale if they are correct. Thanks for your help guys.
