mf 135 3cylgas perkens
(quoted from post at 15:19:13 10/14/14) need point setting and timing
Hi, I have a MF 20 industrial with 3 cylinder Perkins and I've been told that it is basically the same as a MF 135. Given that, the points should be set at 0.021 and the timing should be 26 degrees before top dead center with the engine running at 2225 - 2275 rpm. Hope this helps
