mf135 with powersteering assist adjustment specs
ron1024
New User
I think this is a UK model, I had power steering right and not left. I took the power assist apart found broke spring replaced it still works the same. I need some specs on how to set the steering shaft and nut torque[/i]
Hello Ron,
First of all the UK type steering for the 135 is shown in the attached pictures. Is this the type that you have? The top bearing needs to be adjusted and locked. Make sure that the steering is smooth and free from side to side but is not loose.
DavidP, South Wales
