MF-65 drilling hole in tie rod end
Rkh
Is it okay to drill hole thru tie end-the hollowed part of tie rod is egg shaped and I added a front loader bucket to tractor so I thought of drilling hole thru tie rod and using bolt, lock washer & nut on each side of tie rod thru the collar?
heres the picture
After replacing the tie rod on my 65 with fel the indenture was in the wrong place so I just drilled another to same depth.Don't think going any deeper would be wise.
