morgan in ar
I recently bought an aftermarket hydraulic
pump for an MF 50, supposed to be a direct
replacement. I think it is made in India.
First, it was to wide (about 1/8" wider than
original) to fit through the lift cover
opening. I ended up having to split the
tractor to install it. Now I have the pump in
place and the tractor bolted back together, but
the dowel holes on the pump don't quite line up
with the holes in the housing. The pump is
toward the rear of the tractor about 1/8". Has
anybody run into this before? The pump wont
slide forward any further. The only Idea I
have is to grind the dowels down kind of
tapered on the end so they will slide into the
holes on the pump. What do you think?
