MF265 Independent PTO
Bill C
I bought the parts to rebuild the clutch pack from my MF dealer. The original pack had wave springs and disk with coating. The parts they sent me have 11 springs and pins,7 plates and metal disks. I need help in putting it back together with the new parts. I can't find any wright ups or pictures for reference. Thanks Bill
Start with a steel plate against the piston with the tabs away from the drum bleed holes, these tabs are where the springs/pins will rest on to push the piston off. Place a disk, then a steel plate turned to the next groove. When all are in place install the springs/pins on the first plate tabs, then the heavy final cover plate and snap ring to finish.
