MF 200 loader fit a 65?
Hay hay hay
Will this loader fit?
If so is it bolt on or is a lot of modification needed?
Does anyone have a 65 with a loader? How does it work and will it handle a 1000lb round bale?
Thanks
My 65 utility has a 200 loader. It should have no problem with 1000 lb. bales but you may need counterweight if tires are not loaded. Mine has a large weight box mounted since it has no 3 point hitch. It will still lift the back end off the ground if you try to lift too much.
Larry
Picture did not upload
