55 50 Ron
Is there a Massey model E33 or would it more likely be a 333 and the decal was damaged? A friend says he saw one with the E33 decal.
Thanks, Ron
Massey Harris made a 33 and a 333. there is no E33 listed in the massey data book. Check the serial # tag for the model. Tag should be on the left side of below the battery if it's a 33, below the right side on a 333. If no serial# tag, look for the serial # stamped on top of the transmission cover between the clutch pedal and the PTO lever. It's there, you might have to do some scraping.
