massey dieselmatic
krob
How do the hydraulic remotes work on massey 65 dsl? There are two handles. When one is moved the 3 pt. Drops. The other handle seems frozen.
The one I have the three point works when the left spool is locked rearward. When the spool is centered the right spool will work the remote cylinder with the Draft lever at top of quadrant, this overrides the internal linkage turning the pump off when lift arms reach the top of travel. This is the ONLY time the draft is used at the top.
We could only get it to push the cylinders out but not retract them. Not sure what position the draft control was in at the time. tried moving the left spool and it seems frozen. Can the three point and the hydraulic remote be used at same time?
