TRACTOR MANUAL
freddiep
New User
I just bought what I think is a 1963-64 MF 30 built in BEAUVAIS FRANCE,
needing a operators manual or better yet service manual ...any info would help...thanks #SNMY 1110745
Hi Freddie, Depending on what part of the world
you are in, it was known as the MF25 (usually
USA /Europe) MF825 (usually France) or MF30
(usually Aussie) although they can crop up
anywhere with any label. Predecessor to the
MF130 (same critter in a new set of clothes). 4
cyl Perkins engine (A4-107) very reliable,
usually easy starting though a little
underpowered – has been known to break under
too heavy a load.
If you want to email me direct I may be able to
help with manuals / info if you can’t get
anything better.
Regards … Chas
Evening: The perkins engine is good and most parts
will interchange with the 4-108[except head],
tractor parts also change except for the american
130 version, hydraulic pump.
As for a manual look for a "cylmers" garden
tractor manual in the local library, I found it in
there along with other lawn/garden tractor models,
a big little tractor i guess.
Canadian version is MF25, french is MF825, 25 being the hp rating
Hope it helps
