catskinner22
New User
ok all you smart and wonderful people bought a wood chipper with a4.236 looks like it has been rebuilt recently. The oil pressure when cold is running around 60 to 65 lbs. I checked it all out and sent it out with the crew. when they came in I asked how it ran they advised great. They all left I gave it the once over oil ok water ok. I started it and no oil pressure took oil line off dribble no pressure. before it left that 1st morn I ran it at about 20 min at 1/2 throttle still had 55-60 lbs pressure. The next morn started it 60 lbs. I tore it down today and it has been rebuilt recently. The only thing I have found to this point is where the balancer bolts to the block there are supposed to be 2 sleeves that go between the block and balancer There was only one. Do you think this could be the problem. I know this is a tractor forum but I know tractor guys have been there done that
