HI.
I am going to look at a engine for MF 65 gas, G176. I am thinking of performing a compression test. What PSI would be acceptable. What PSI is not acceptable. I know the cylinders should be within about 10 percent or somewhat close to each other not 30 or 40 PSI apart. Been a long time since I have even done a compression test.
Any other suggestions to look for while looking at engine. Breather tube on valve cover for blow by?
I bought a 58 MF65 with thrown rod. Mechanics report has broken rod and cam. I have not had the engine apart to see if block is any good.
Thanks for any help.
