MF 135 gas tank availability
Wildturkey
New User
I've got a 135 with Perkins gas engine. The gas tank is leaking and I tried to fix it with epoxy stuff which worked for a few months. Now leaking again. No one seems to stock a tank for this model. Does anyone know where to buy a new or used one? Thanks
WT, look to the upper left: Marketplace, second line
down, tractor parts. Click and find your
tractor/model. They show 2 tanks, one for diesel and
one for gas. Also show/list original Part#'s. Good
Luck!
I had a leak on my TO-35 gas tank. I took it off and took it to a tank repair shop which coated it with some material and the tank hasn"t leaked in the last 4 or 5 years. Before that the tank had a patch on the outside that started to leak again. The repair cost me about $100.
(quoted from post at 00:37:26 09/14/14) The Perkins gas, and Perkins diesel engine in the 135 use the same tank. AGCO part number 189468M93.
Thanks for letting me know that the Perkins gas tank and diesel are the same. I just ordered one from this site.
The 3 cylinder Perkins gas, and diesel (the AG3.152, and the AD3.152) engines use the same block, crankshaft, flywheels, camshaft, rocker arms, exhaust manifolds, and other small misc parts. You could convert one from gas to diesel if you had all the necessary parts from a diesel, or if you had a complete AD3.152 diesel it would bolt right in.
