The bushings on my MF 50 Hi Arch spindles are worn out, so I decided to replace them. I took the wheel off and the top arm and half moon key. The spindle only slides about 1/3 of the way out and comes to a dead stop. I took the grease fitting out just to be sure. I also filed the top of the spindle in case there was any mushrooming. No luck. Still will not move. Tapped it a few times. Nothing.
Any ideas. It turns freely as well as slides up and down. I filled it full of PB Blaster to see if that helps.Any ideas?
Thanks
Marion
Thanks
Marion
