Hello,
Referencing my previous post about brake seals (http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=152214), I've run into a new snag.
One of the left brake driveshaft seal housing studs is much longer than the rest. The lower forward one appears to hook through some component in the transmission.
I've taken a photo, attached, and the good news is that this item doesn't appear to be threaded, BUT (notice, BIG BUT here) it sounded like something went 'tink' when I removed the long stud. I've used a long magnet, and haven't found anything yet, but you know how THAT goes...
Before I reassemble, I'm trying to determine if there is anything else there that might have fallen or can cause damage.
I'm suspecting I probably need to gain access to the top of the transmission, the larger plate aft of the transmission shifter housing.
This tractor has the power lift attachment installed, and unless I'm wrong (please tell me I'm wrong) it appears I have to remove the pto shaft to remove the large plate on top of the transmission.
I am willing to remove the PTO shaft if necessary, and already have the front bearing removed, but am stymied with the rest of the steps to get the bugger out.
Honestly, this project went from a 'quick clean and paint' to a nightmare over the past couple months (actually, since I shattered a piston at idle last year...), and once the brakes are done, I'm hoping to put some paint on this beast and get some wood split!
Any and all advice, encouragement and abuse is welcome...
Brake Seals leaking
Brake Seals leaking
