1080 mystery part, well try this again.
jr1983
As I have been unable to figire out how to attach a pic with an
android I will try this another way. My 1080 hydraulics quit
working. I pulled the right side access plate off because that
seemed to be where to start. And a piece of what I think is part
of the linkage fell out. Its triangular has an adjustment bolt
(approximately 6mm thread) at the top. The piece is about 2"
(50mm) wide at thr bottom and about 4"(100mm) tall. The
adjustment screw is attached at the point. Any ideas what this
is or where it goes?
I am not that familiar with hydraulic system on a 1080, but think the hydraulics wouldn't work properly, or if at all without that lever. The power steering is run off a separate pump that's on the engine.
