Terry Spears
New User
Trying to reassemble and adjust my lift cover (7/8"). Following the book, I"ve had to disassem ble and change assy sequence at least 5 times to get it together (makes me question my book).
Anyway, for adjusting the book I have says...
Move Pos control to transport (check)
Locate draft control lever between sector marks (check)
Place adjustment wedge MFN163 to hold dash pot plunger out (I use a piece of wire)
Locate ram arm using MFN 970 (I"m using .47" shim)
Apply 3 lb force to vertical lever and adjust for .000-.002 clearance to dash pot piston.
ALL OF THIS WORKS OUT FINE, but then it says move draft control all the way up and position control to transport and repeat the above for position control adjustment.
But, When I do I have to readjust the vertical lever (and lock nut bolt) by about 5/16" because lever moves away from the dash pot plunger. After adjusting this back to .000-.002, the position control lever wont move at all. If I try to move it I can see it stressing the mount for the control lever (that holds the adjusting bolt) so much that if I force it, it could break it loose from the plate that mounts to the cylinder.
What am I doing wrong?
