Bonnan
Son was brush hogging with the 65 yesterday when he hit a tree while turning. The bracket that is bolted to the axle housing and supports the left lower lift arm broke in two. Are these weldable or can I buy a replacement? We need it now and prefer not to start searching the bone yards.
Thanks for any suggestions.
Hard to tell from your description, but I've found that there's not much cast that can't be welded successfully using proper technique: properly "V" out the break, pre-heat, nickel rod, slow cooling in sand or covered in blankets.
Whaddya got to lose by giving it a shot?
