Terry Spears
New User
1965, 165MF seems to be missing a spring that connects the position control cam finger to the cam mechanism.
According to the manual the spring removal and assy is part of the process but I don't see one. It does seem like there should be one as the spring loaded shaft pushes all the way out of the hole and the long spring comes off if I push the PC lever to the bottom of the quad. Can anyone post a pic or part number?
My cam mechanism was damaged which might explain the spring missing but I haven't found it inside the case either
