Hello,
I had a leak under the tractor I'm rebuilding, trans oil. I figured it was minor, but I had to check the brakes anyway, SOOOO.... Pull the brake plate and water/gear lube POURS out of the brake housing, which is, of course, completely filled with decades of sludge... Off to the other side and , no surprise, the same issue. I can literally watch the oil pour past the brake shaft seals.
I'm trying to figure out, from the parts book, what seals I need to buy.
My 101 Jr RC (Single front wheel) has the band brakes (I need to get them relined) but the shaft seals absolutely must be replaced.
Can anyone point me to the correct seals, either by part number or location in the parts book?
These aren't the axle seals for the wheels, but the shaft seals for the shaft that the brake drums mount to.
After that, it appears I remove the housing, bang out the old seal and carefully press the new one in place.
Thank you to ANYONE who can help..
